Keyroll issues
  • OliverTwistd
    • Sep 2009
    • 6
    Keyroll issues
    Hi all
    There's been a keyroll in my area and I've lost channels. My setup is a bit different from most others as I use a dvb C PCI card in a PC. usually I can use keymaster to get the updated numbers but I havent used it in a few months and when I tried it today it doesnt seem to be updating. I've tried the version on here but it is doing the same thing.
    Does anyone have any ideas? I'm using KM v1.2, is that old? I have the CC toolbar from a long while ago, showing the same old numbers. Is it worth updating the toolbar?
    Any help appreciated
  • davie1888
    • Sep 2009
    • 52
    Keymaster won't update m8, not been a key roll since last Oct, your area has either taken the 3.7 update or your on N3
    D A V I E
    1188
    • OliverTwistd
      • Sep 2009
      • 6
      Hey Davie
      I'm pretty sure its not N3 changeover yet. Someone at the end of the road still has a working box so it is something daft like updated keys.
      The thread but one below this one was talking about the same thing.
      • Fergal
        • Aug 2008
        • 1007
        Do a scan if that dont work you might have to delete all your channels first then scan
        • dbc007
          • 42
          I have the same problem. Some premium channels are working but lost other channels. And I know a friend in the same area has got all the channels.
          Done factory reset and rescan etc but no joy.
          Any other advice is welcomed. Don't thing it is the N3 issue.
          Thanks in advance
          • cactikid
            • 12017
            did you delete all data first and scan from a direct feed,also check your provider for faults in your area as some places went down.on some boxes you also had to enable emu to view.
            • dbc007
              • 42
              I have starview 4 and I installed v1.12 and it worked !!!
              • OliverTwistd
                • Sep 2009
                • 6
                Hey all
                dbc007 did you use the keymaster version from here? Is that v 1.12 coz I downloaded that yesterday but when i run it it still shows old keys.
                I know thats whats needed to get things running again, without it rescanning wont fix a thing.
                Does anyone know where I could get the numbers from?
                Wasnt expecting to lose things before N3!!!
                • Fergal
                  • Aug 2008
                  • 1007
                  The k*ys have not changed since october have you deleted the channels and done a scan.
                  • OliverTwistd
                    • Sep 2009
                    • 6
                    Guess its the only thing left to try mate.
                    Off for a full rescan
                    Heres hoping
                    • OliverTwistd
                      • Sep 2009
                      • 6
                      Thanks peeps. Managed to get it sorted.
                      • ashali152
                        • 37
                        lost all box
                        box cut off now east london area
