HiDoes anyone know were i can find the area code for wigan because when i try the nearest places to my area all the channel are jumpy and often freeze.
Need help for arnet kryptview
most of my channels on one box are stil jumping with the latest firmware i was told to try the signal deviation which is off by default but not made a difference.signal deviation is on the 3rd one down in menu cannot remember what it says press ok then you have 2 to choose from top 1 is tv settings and the bottom one has it.try +1 or -1 first
<--delboy13 added 0 Minutes and 46 Seconds later...-->
when ever i do factory default firmware is still there but no channelsComment
I don't think the firmware is your problem.. It's more likely a bad connection with your scart or cable..
Doing a factory reset doesn't wipe out the firmware. After a reset you have to go to automatic search then set your network type and then choose your network ID and finally press the green button. If you do a factory reset make sure you know what your Network area and Network ID is otherwise you're in trouble. Also it's a good idea to delete all channels before doing a factory reset, for some reason the new channels get mixed up sometimes if you don't.
The latest firmware is very stable I've tried this on well over 10 boxes.. though some areas do prefer the PVRepg file.
Deviating the tuner is easy enough and I've played with it and it does increase the quality strength but delays the tuning considerably. This option is not available in the April firmware.
Debbie. If you use a scart lead make sure you're set to RGB and PAL in your options
Regards.Comment
arnet box
can anyone help me with channels im missing on the arnet box,i have the latiest update but am now missing sky sports channels 1,2,3 but have exra and sky 1,2,3 are missing along with other channels,do i need the area code for bolton and if so does anyone know it cheers?:Comment
any one any ideas what i can do?
