Scientific-Atlanta HELP
  • Sniper^uk
    • 42
    Hi all got hold of a Telewest Scientific-Atlanta box just want to use it for free channels for the kids room but when i switch it on it says any idears please any help would be greatful
    Guardian has determined that your software must be updated this upgrade will be performed when the network is available this may take 20 minutes or more please stand by.
    Guardain version 1.0 Mon Feb 27th 2006
  • chris31560
    • Feb 2010
    • 912
    hi m8 wot area r u in?? ie t/w ntl c/w, also when u plug box in wot does the lcd screen say...
    A LITTLE THANX GOES A LONG WAY
    • Sniper^uk
      • 42
      c/w just says boot then you hear it booting up then one light on the front keeps flashing will not switch on only when i press left right up it goes into the Guardain thing
      • Sniper^uk
        • 42
        just pressed stand by while it said it was performing the update then it said performing fast update to the network went onto another screen mmmm
        • chris31560
          • Feb 2010
          • 912
          hi m8 it sounds to me like the box is trying to update, go into em and check ur settins ie def frq/ simble/ netid, if u think these r all ok then u need to do a forced update, the way to do that is when booting up box hold in standby button and ok button at same time the box should then perforn an update...
          • Sniper^uk
            • 42
            yes thanks m8 done that but its updateing now about 1 hour numbers and letters on the display on the box ill see how it gones thanks for helping
