HD picture quality - virgin v sky
  • asuk
    • Aug 2008
    • 37
    #16
    i love espn hd on vm.
    • john8867
      • 152
      #17
      sorry mate, meant his comment that sky was much better than virgin!
      • scotty_dotty
        • 124
        #18
        If the res is the same you probably won't see any difference. Unless your puting 2 of the same tvs next to each other running the 2 sources together then why even bother.
        Had an ex7000 and just got sky HD in and personally the only tweek I found that's been a bonus on sky HD is that you have seperate contrast settings in the sub menus which is great for boosting the whites on my pana plasma.
        And I prefer the menus etc on the sky set up.
        You can get itv HD on sky just now, go to the general sat section and there's a post with a tutorial.
        TYPICAL BLUENOSE
        • Fspiders
          • 107
          #19
          When VM get sky hd I suspect you'll see a difference then.
          Sky transmit to their sat and that goes direct to our dish, where as VM will have to pick it up from sky on their massive dishes then pump it through their system to eventually get to us.
          sky channels have always been a second or so behind on vm compared to sky dish transmissions and digital free, so I'm guessing there's gonna be some kind of degradation along the way.
          • BHX
            • 30
            #20
            On both platforms it's 1080i.
            It's A Lot, not Alot.
            • ManofScience
              • 650
              #21
              it's digital so i would doubt there's any sort of signal degredation probably only lag
              • screwc149
                • Mar 2010
                Deffinately SKY, i have tried both and after the first month of owning vm i regretted the swap and promptly moved back to sky.
                • oldie
                  • 32
                  #23
                  I have both a eurovox ex 7000 and a dm800 sat hooked up to a sammy full HD telly. I can flick from vm to sly while both are on, say Nat Geo HD channel.
                  And in my opinion Sly is slightly better quality than vm.
                  Note: Viewing Pay TV without a valid subscription is illegal! All the files available here are kept for experimental and educational purpose only!
                  • BHX
                    • 30
                    #24
                    Some channels like BBC HD VM get a direct wire feed, other channels have to come from satellite which use 'MPEG4' variant and then re-encode it to MPEG2.
                    • opsmonkey
                      • 5379
                      #25
                      Originally posted by flyingpig
                      I have the HD package now on Sky at the half price deal, and I have to say, I would not pay the extra dosh for the HD pack on either vrigin or sky if it was full price.
                      I have a full 1080p and a 1080i TV and there is absolutely minimal difference between the 2 when watchin TV. The only time you can tell is when a very fast moving scene is on,,,
                      Virgin and Sky are the same quality really..
                      get real the difference between HD and SD is massive..
                      If you are watching something filmed in SD on a HD channel then the difference is minimal as its just uprated SD.. for example C4HD is showing Friends, now this isn't HD as it was never filmed in HD
                      However watch the live football on Sky Sports HD1 tomorrow at 4pm and then compare it to the same match on Sky Sports 1..
                      If you cant see the massive difference in quality, sharpness and color then you need to check that your Sky+HD box is set up correctly, make sure you are using just a HDMI cable and not a SCART.. If you have the right settings and are using a HDMI cable and you still cant see the difference then go to the opticians ..
                      Programs not filmed in HD but broadcast on a HD channel are just slightly uprated SD
                      Programs filmed in HD and broadcast on a HD channel are true HD
                      • flyingpig
                        • Aug 2009
                        • 930
                        #26
                        Yup..
                        My box is setup perfect..... No problems,,,I dont have a scart connected,,,,
                        On SkySportsHD and nonHD you can notice a difference, but not enough to warrant the extra dosh required.
                        When you watch a blu ray at full 1080p you can notice a differece between that and Sports HD..
                        The difference in quality is minimal...
                        • opsmonkey
                          • 5379
                          #27
                          minimal...?
                          you must have a budget HD TV or dodgy glasses
                          • flyingpig
                            • Aug 2009
                            • 930
                            #28
                            Haha,,,,, Nah,, A Panasonic 42" Plasma 1080p, and an LG42"6000 Plasma 1080i.... With a Bose Home cinema system...
                            No Scarts, all HMDI and optical audios. TV, Sky, Dm500 all setup correct.
                            My eyesight is 20/20 .. although the hearing has well gone..
                            • opsmonkey
                              • 5379
                              #29
                              well the difference is massive on my 37" LG LCD 1080 Full HD.. I'm using the latest Sky+HD box with gold HDMI cables..
                              SD is grainy.. Sky HD is just as good as any Blu Ray played on my Harman Kardon BDP-10
                              • HoTTDubbER
                                • 778
                                #30
                                agreed
                                for instance look at the ball when in play and being passed around the pitch in the standard tele camera in SD its blury and just looks like a white circle
                                in HD you can see the spin on the ball and the pattens all over it there's a HUGE difference
                                Qualified Jedi Master
                                Virgin VBox
                                x2 PS3 JB FW 3.55
                                X2 Wii 4.2E soft modded
                                4x DM500S + JADE PLI
                                Openbox HD S9 & S10
                                DM800 PVR + BLACKHOLE
                                Dedicated Linux Debian Server
                                1.2M Dish Sky UK, Viasat, Sky IT ,JSC ,Tring+ Cards
                                90cm Fortec Star Motorized Dish
                                Virgin 50mb Fibre Optic Broadband
                                Xbox 360 Samsung LT 2.0.1 No AP25 + Liton LT 2.0
                                Microsoft Approved and Certified OEM System Builder
                                Subaru Impreza GB270 Owner
                                http://online-console.com
