digivox and digivox xl help!!
  • bajanboy
    • 18
    Hi Floks I am using a digivox in barbados for MCTV which is working great some one else programed it. the system info screen says this
    model name = digivox
    s/w version = v02-2.500bk
    boot version = 01
    date = 1.jan.2007
    I got a new digivox xl and was wondering where i can find the loader and file or files to get the new box working Thanks.
    MCTV = Multichoice TV in Barbados.
  • cactikid
    • 12017
    t he old non working file over was vers 2.500 we had to update to v.2.800 to work again.
    xl all black u can use same loader for both but not files,u will need v1220 on xl only might be on site?
    • bajanboy
      • 18
      thansk for reply
      I am still using the 2.500 here and its still working fine. not sure if you need a new file for elsewhere but we still use it here in barbados and its working fine thanks. I will try to find the one for xl... cheers
      • DigiDu
        • 8
        I also have a Digivox XL but i cant get the firmware to go onto the box it keeps saying fail to open com-port. Access denied. What do i need to do. HELP
        • cactikid
          • 12017
          are u using a pc xp and serial port and null modem cable? have u tried changing com port to 1 or 2 or 3 or 4 ?
          • axel1f
            • Oct 2008
            • 57
            try the file in tcb.cc toolbar for digivox xl
            • cactikid
              • 12017
              9 times out of 10 wrong cable is used u need a null modem cable.
              • bajanboy
                • 18
                cactikid ok got the digivox xl working and just updated it with the latest bin and so far so good also got the silver digivox update from v2.500 to v4200 and so far so good. Thanks guys
                • bajanboy
                  • 18
                  Is there any way to correct the EPG? all channels have the same number 5000 ((thanks))
                  • cactikid
                    • 12017
                    factory reset 0000 to delete,power off at back/on autoscan again it should be fine as in named channels.
                    • rix2011
                      • Feb 2011
                      Does the digivox xl still work?
                      • Shady
                        Shite Link King
                        • Dec 2010
                        • 6404
                        . no! not for a LONG ~~~~ing time
