DIGIVOX XL USB black help needed
  • moh1234uk
    • Apr 2010
    • 6
    software ver: 1.06
    model code: 3176
    loader ver: L-01
    Last update: aug 18 2009
    I bought this box in feb 2010. as you all know some daysback the box is not working. pls can you let me know what to do. do i need to update the firmware - if so how, can i do it using a usb stick. i do not have any wires for the box.
    also i went to system info. typed in 1004 and it gave:
    nagravision (OK), set default key(OK), KeyCode (ENABLE/DISABLE option)
    pls help
  • ManofScience
    • 650
    where are you?
    do you know about Nagra3 ? this will kill all boxes. no channels, no wayback. nothing. only way you'll get tv is to subscribe.
    read this : http://www.digital-kaos.co.uk/forums...-3-faq-105985/
    and check post #259 here to see how long you have left : http://www.digital-kaos.co.uk/forums...tml#post562576
    if it's N3 - it's GAME OVER. There is no fix.
    • moh1234uk
      • Apr 2010
      • 6
      Originally posted by ManofScience
      where are you?
      hi i know about nagra3 - but im in leicester . i just spend ?150 on the box. if i update my s/w to 1.07 will it work?
      also i have heard some boxes overcome the nagra3
      • moh1234uk
        • Apr 2010
        • 6
        update 1.07
        hi i have updated firmware to 1.07 - still does not work
        • cactikid
          • 12017
          have you factory reset 0000 to delete and auto scanned from from wall socket to box no splitters,find channels yes,when finished exit out,then press menu-system info-ok1004 emu to on and press the set default key also,exit out to a sly channel
          it should update.
          • mashruk59
            • Apr 2009
            • 6
            it should update.
            No, I tried it. I am having the same problem. I live in Hatfield, Hertfordshire. Is it Nagra-3 jone?
            • cactikid
              • 12017
              if you see waiting for code update on movie channels and some others it sounds like you are on nagra3.there is an updated thread around forum stating areas on n3.
