Self Installing 2nd Cable Box
  • ptercook
    • Oct 2008
    • 66
    Now being the proud owner of a dreambox im wondering if its possible to run a cable from the box outside to my bedroom and use my virgin box as a 2nd freeview box?
  • shady77
    • 982
    yes it is possible, you will need a cable splitter. but you may get some signal loss on your dreambox and have to buy a booster.
    • thered
      • 4915
      yes mate but depending on how good your signal is you may need a booster
      beat me to it shady77
      • shady77
        • 982
        mwa- ha ha ha haaaaa
        • ptercook
          • Oct 2008
          • 66
          would i install the splitter on the outside box? My current virgin box registers a "good" signal strength i presume thats like bars on a mobile dont mean much.
          What sort of wire would i need also where is a good place to get it from maplin?
          • cgscott
            • 3513
            The cable will cost you about a quid a metre at maplins.
            Also you will need connectors etc.
            I split mines over 10 metres and didnt need a booster.
            Where you from ptrcook.
            Your names familiar?
            Patience is a virtue.
            • ptercook
              • Oct 2008
              • 66
              just a nickname after the late great comedian im in the north west area preston to be specific. would i need some crimping tools you think?
              • thered
                • 4915
                get some decent grade satellite cable cant remember which but when you buy they should have a couple to choose
                you should be able to run the splitter from your box outside to the bedroom no problem
                if you find you need a booster for any signal break up try argos as they have a no quibble guarantee on every thing so its very easy to take back
                • thered
                  • 4915
                  i just use a stanley knife and leccy tape
                  but whatever you fancy m8 it makes a neater job
                  • ptercook
                    • Oct 2008
                    • 66
                    sounds like a plan. So i would just need the coax cable and a adaptor that goes into the back of the box. would these 2 do?
                    this cable
                    Satellite TV Cable FT100 > Maplin
                    and this plug
                    Twist-On F Plugs > Maplin
                    • thered
                      • 4915
                      sure will but dont forget your cable splitter
                      • ptercook
                        • Oct 2008
                        • 66
                        what diamater F plug would i use CT100, RG58, RG59 or CT125 ?
                        • young
                          • Oct 2008
                          • 316
                          make sure you dont leave any frayed ends though
                          • smoggie
                            • 863
                            I have had cable fromt his guy, price aint too bad 20m White Cable Extension / Flylead for Sky & Freeview on eBay, also, Other Satellite Cable, Satellite Cable Freeview, Consumer Electronics (end time 15-Oct-08 14:19:18 BST)
                            • thered
                              • 4915
                              your talking to technical now for me m8 but normally if you buy your cable and f-connectors from the same place they will give you the right size
