Connection from Cable to Dreambox
  • ptercook
    • Oct 2008
    • 66
    What is the adaptor i need to connect the cable to my dreambox. the cable wire has like a satalite style adaptor on it and the dreambox is like an old school tv ariel adaptor.
  • thered
    • 4915
    you need one of these m8
    10 x F to Coax Adaptor Adaptors Starview Eurovox DBox on eBay, also, Cable Boxes, Satellite Cable Freeview, Consumer Electronics (end time 09-Nov-08 22:24:11 GMT)
    • ptercook
      • Oct 2008
      • 66
      Cheers ive got that now but when i automatically scan for channels i get
      trying to find used transponders in cable network. Then it goes through all frequencies and shows failed for each frequency then after going through them all i get
      error - failed to scan (error starting scan)
      • thered
        • 4915
        right m8 you need to input either 6.887 or 6.952 b4 you scan depending on area
        just change as required
        • portbhoy
          • 717
          Or try a bruteforce scan, takes longer but then you'll pick up whatevers there
          • thered
            • 4915
            what image are you using m8
            • ptercook
              • Oct 2008
              • 66
              hi mate, im using Gemini v3.8 for DM800 downloaded from the downloads section.
              • thered
                • 4915
                what cam are you using
                • ptercook
                  • Oct 2008
                  • 66
                  not sure i dont think i have one installed? where would i get one ?
                  • thered
                    • 4915
                    try this
                    RapidShare: Easy Filehosting
                    • ptercook
                      • Oct 2008
                      • 66
                      very much appreciated, so i just ftp these into the relevant folders and restart the db?
                      • thered
                        • 4915
                        install via ftp to usr/temp
                        then blue button on remote addons/manual install click ok should install
                        then go to top change cam to evocam 2.17 should be ok
                        by the way install as it is the box will unzip it i made this mistake
                        • ptercook
                          • Oct 2008
                          • 66
                          legend!!! its working
                          • ptercook
                            • Oct 2008
                            • 66
                            any tips on what plugins skins are useful to a newbie?
                            • thered
                              • 4915
                              glad you sorted m8
