Virmin V+ Samsung Box Splitter Help.....!!!!
  • scotlandboy
    • 24
    I have Virmin V+ SAMSING 2010 Box installed few weeks ago. Now I want to see exactly the same channels on my TV Up-stairs so I went and bought*** 3 Way Splitter Kit Cable TV Starview NTL Virgin Media *** from Ebay for ?6.50 and this guy got 100% Feedback. Anyway, This is NOT Working, I can connect all up OK but when I tune-in my Up-Stairs TV I can not get channels from VM New Box, I never had Problem this Problem before in my OLD VM Box but then that Box had Cable-in and Then Cable-out input but new one only got Cable-In , I know Video Sender is another option but I much rather use this splitter as all wires are in place already...PLEASEEEEEEEEEEEE HELP ME PLEASEEEEEEEEE
  • cloudnineuk54
    • 530
    surely you need another box upstairs? or not ,cable straight into tv not sure thatll work
    • scotlandboy
      • 24
      what do you mean by ***cable straight into tv****please mate explain
      • scotlandboy
        • 24
        explain what you mean please mate...
        • satsmo
          • 6397
          As said above you need another VM STB or use some video senders, (you can only watch the same channel on both boxes if using a sender).
          • cloudnineuk54
            • 530
            trying to understand what youve done,ie cable comes in downstairs,split,one to vm box downstairs? whats upstairs just the cable you split?
            • scotlandboy
              • 24
              yes upstairs COAX White Cable which goes in the Arial Slot of back of TV
              • cloudnineuk54
                • 530
                ok well thats no good you need something like mentioned above video senders,or an old video recorder could be used,or another box,just the cable upstairs will not work
                • boomer39
                  • 2818
                  surely the tv upstairs is under the same conditions as the one downstairs? spitter from v+ box goes to 2 tv's...
                  YNWA..
                  • safc1234
                    Try a modulator, it conferts the single form box through scart and it has an out put for the single coaxcel lead i have one cable all of the way through house can watch v----- or sv 6 in eny room
                    • nialler
                      • 141
                      are you sure there is no "rf" out or point on box that says "to tv" etc.
                      see this link as an example
                      Dont forget to say thanks
                      • scotlandboy
                        • 24
                        Yes I have seen your Picture and I can re-confirm that your picture is showing all the correct connections but on my V+ Box which is made by SAMSUNG DOES NOT HAVE to TV and ANTENNA option AT ALL. Everything is all there but these two above things are missing..How Bizzaarreee...or you think they are clever...? Can you still HELP Please
