Digivox Firmware v3330 for T (MMDS)
  • metalgear2k2
    • 12
    #151
    Hi guys, I have the Digivox-T with the latest firmware and it has been working away pretty good, some of the Mtv channels were not working but now the sound is gone on RTE 1, 2 and TV 3, anyone know why or how to fix it?
    • Wale04
      • 44
      #152
      Hi
      I'm also having same problem with my box, some station freezing up and some losing sound.
      Any solution out there????????????
        delete the channels that have no sound and do a rescan they will come back in with sound the will be named different like tv4301 just rename them as they should be
        • metalgear2k2
          • 12
          #154
          I deleted 1 channel, RTE 1 to check this but when I do the rescan its not finding any channels? Help?
          • metalgear2k2
            • 12
            #155
            can anyone help?
            • quaid
              #156
              Lads,
              not sure if this is the same issue as i had a couple of weeks ago, i came home and RTE1, RTE2, TV3 and TG4 had no sound.
              to sort it out i had to do a factory reset on the box and reflash with the firmware, then do a rescan and all the channels came back with a couple of extras, some were in a different order but they were grand other than that.
              Digital Kaos - Downloads - digivox_ter_v3330_090806
              • tomhick024
                • 559
                #157
                Originally posted by quaid
                Lads,
                Good info mate, but no need to reflash the unit, just do factory setting, power off unit, turn power back on, turn on emu and rescan!!
                Whatever!!
                • cactikid
                  • 12017
                  #158
                  power on antenna before you scan.
                  • desibaba
                    #159
                    thanx for the info
                    • vmd1916
                      • 109
                      #160
                      digivox t
                      hey fellas i done factory reset to get sound back in those few channels,and as you said worked a treat ,but lost all channel names ,just numbers which is annoying, will i have to do a reflash has box lost some info when i factory reset....
                      • cactikid
                        • 12017
                        #161
                        no its a common thing factory reset and continue will bring them back ,its fairly common.
                        • vmd1916
                          • 109
                          #162
                          what is most recent firmware for digivox t on mmds , ireland ,ch***s??being a while since i flashed ,eh boxes i mean..
                          • metalgear2k2
                            • 12
                            #163
                            more problems
                            Ok so I'm trying to update the firmware on my digivox-t and when I check the system info it still says the date of release is the 22nd of Dec 2008 which is the last one so I dont htink its getting flashed properly.
                            I did a factory restore to get some channels back but now I have none and the auto or manual scans dont work, I have emu and antanna power on but still doesnt work!
                            could and one help me please?
                            • vmd1916
                              • 109
                              #164
                              did you you use v3330 it worked for me ,just check your codes are ok,if not that its bad flash , try again with v3330 ,the link is on this thread,double check emu on,,when i flashed with this i got 6 august 2009, hope this helps
                              • pidgion
                                • Mar 2009
                                • 9
                                #165
                                digivox firmware v3330 for t (mmds)
                                hi guys i have that firmware on my box and still lost nearly all my channels any ideas or help thanks
