Ddigital Duo
This topic is closed.
  • zoonie
    • Apr 2009
    • 5
    #16
    Hi folks the duo is a very easy box to setup including flashing and performs on a par with the Krypt A780. The remote is not complex and all channels are auto sorted.
    The box is the smallest on the market at 4 and half inchs long aand is designed to sit out of the way with a wired eye for the remote.
    The box uses the same s...er as the starview some say is a down side, I have tested both boxes and connectivity are about the same not 100%.
    Cost wise its aprox 50 quid cheaper and in an uncertain market it measures up.
    Hope this helps
    • zoonie
      • Apr 2009
      • 5
      #17
      A bit of small tut I did for another Site
      Trialled one yesterday and was up and running in 5 mins. The box is very small about a quarter of the size of the A780.
      1. on a usb stick firstly make sure its formatted to fat 32 then download the image to flash.
      2. Plug the box in and the usb stick and fire it up you will come to the Channel manager screen go to third icon on the right (Box with a musical note) and select usb
      highlight Ddigital- duo_2.12.ups click ok button on remote select sw upgrade when complete the channel manager will come back
      3. select auto search the on symbol rate select area ie 6952 then select search the box will now start to scan for channels once completed press the ok button.
      4. Plug the network cable in select options from the main menu and select network the select ip setup this will confirm you have a valid ip.
      Now select net application and change type to Ustream for uk then exit to tv screen
      5. Press the ok button on remote then the yellow sort button select the way you want the channels listing and thats it you are done.
      6. Pressing the right and left button will change the cats ie sport etc and the Ddigital does auto sort the category's sports movies etc
      Hope it helps
      • mukeina
        • Jun 2009
        #18
        where can i purcharse the box Plerase anyone.....
        • Brydo
          • 27
          #19
          update- still working fine, in an N3 area. yes, small. easy to use, cheap and chearful . Happy days are here again
