Enter Codes on Starview 3 Box Super
  • dazbad
    • 5
    Update:
    Latest keys work for TW in Birmi***am
    I have the starview 3 Box Super
    How to Edit codes manually.
    Menu - 1570 - Nagravision - Select TW - Select Key 00
    To enter the keys use the following
    Pause (A)
    Audio (B)
    RED (C)
    GREEN (D)
    YELLOW (E)
    BLUE (F)
    0-9 use 0-9
    Edit Key 0 and press OK to save, then select Key 1 and edit then press OK to store.
    Press Exit and check EMU is still ON then Exit, Exit back to main screen and select 511 to check key works.
    Use keymaster from http://www.digital-kaos.co.uk/forums...ymaster-12893/
    Provider Keys (just to check)
    TW 5A 01
    C&W 5C 01
    NTL 54 01
    Chorus 5E 01
    Omne A0 01
  • homerj9
    • 18
    Originally posted by dazbad
    Update:
    Pause (A)
    Audio (B)
    RED (C)
    GREEN (D)
    YELLOW (E)
    BLUE (F)
    0-9 use 0-9
    TW 5A 01
    C&W 5C 01
    NTL 54 01
    Chorus 5E 01
    Omne A0 01
    worked for me too over in wton please work until wolves kick blues arses on sat nice one dazbad no offense by the way
    • dave8642
      hi i am new to this can someone please tell me what i need to edit is it the key data or the key number i am on tw
      many thanks
      • tweenage
        • 60
        why are no links for keymaster working? sheer volume of demand?
        • zeeshan
          • 5
          i cnt download it yyy?
          • excelence
            • 42
            this site has helped me out alot but cant download anything
            _______________________
            Victoria concordia crescit
            • Zackery
              • 44
              can someone out their please give me instruction on how to enter the new codes into the the box super 3 from start to finish along with the new codes .
              • bsr627
                hi there im in the glasgow area and i have the box super, and i seem to hav lost all my channels can any1 help as im new to al of this malarky it is saying on the screen data is being updated?
                • leonkurd
                  • 4
                  hello
                  hello
                  • leonkurd
                    • 4
                    hello
                    hi can any one please any one tell me code for the box super 3 ? pleaseeeeeeeeeeeeee
                    • leonkurd
                      • 4
                      I lost all my channels can any1 help as im new to al of this malarky it is saying on the screen data is being updated?
                      • jtjtjt
                        do you need to plug the box into the computer to do this ? what exactly do i do , i havent a clue with these boxes
                        • dazbad
                          • 5
                          People are having problems downloading the keylogger prog so here is a mirror site
                          You will find the download to the keylogger and the latest starview 3 software. This will re-enable the auto mapping of the key codes (at the moment)
                          To update the box super, download the GT_ROM_8.02E and un rar the file. Use a Null Modem cable on your COM 1 port - Switch off the box then switch it on. When it says ON press download on the software. It will count to 100% and then reset - You may have to perform an automatic search of the channels again.
                          If you have to do it manually then use the keylogger to view the codes (internet connection required - Just press Reset)
                          As my initial post stated, press menu, then 1570 to open up the CAS menu. Press OK on Nagravision - Change the Provider (using Left or Right Arrow Keys) then cursor down to the Key Number (00 or 01) cursor down to the main string of numbers and change them
                          On the Starview 3
                          Pause = A
                          Audio = B
                          RED = C
                          GREEN = D
                          YELLOW = E
                          BLUE = F
                          For numbers 0-9 use the keys 0-9
                          After changing Key '00' press OK to store, then change the key number to 01 and do the same. Press OK to store, then press EXIT, EXIT and EXIT, then select 511 and check S*y S*r*s is working.
                          I hopethat helps people.
                          • phantomhost
                            thanks dazbad
                            • jasonmaynard1970
                              hi can anyone tell me the program 2 reflash my super box3
