got a ddigital box and haven't a clue how to enter codes! just done my starview2 and got that working fine. Anyone got any ideas?
HOW DO YOU ENTER CODES ON A DDIGITAL BOX?
In on n*l and living in dublin but when entering the keys it does not give an n*l option, it just gives D+ etc. Does anybody know which provider i should enter the codes into???Comment
hey you wont need to download the codes if you put the software/firmware in
i have put the new update firmware in for my ddigital box . i got them from here i think his handle is satimo . you will need :
mv_envision
ddigital_uk_20081128_api firmware .
once you got thoughs open up mv_envision.
click on sat got to the brows button locate the file double cick .
connect you box to yor pc via the cable make your its off from the back but still pluged into the socket . now at the same time on your pc and your box from the back hit start on you pc and flick the switch on you will see it on your pc loading etc and when its done thatit will say sucessful close program switch of box and connect toy pc priovider at this point you will need toenable the channels in the main menu type 8888 and enable channels and then go to scan . if your box does'nt detect and channels go to the system and choose from the drop down menu of the provider after each one chosen recan mine was the 3rd 1 down
good luck
oops i got the firmware but i only got the fta channels none of the sky or anything els just rescanning under a diff prov and see what hapens.Comment
