New Box
  • chevythunderz28
    New Box
    Just bought a TheBox PVR, and major headaches. Guess I'll try some more searches. I've no clue how to enter keys, any pointers?
  • ServerTroll
    I can tell you how to get to the keys unfortunately there seems to be no way to manually change them
    Select Menu > Scroll down and Select System Setup,
    Select Parental Control Press OK, Press i and then 2007
    This will open up a Hidden menu called the CAS System
    (Do this quite slowly because it can be a bit hit and miss)
    Scroll Down to Highlight the Nagravision I/II select OK
    On the Provider ID Line select your provider by using the l
    eft / right arrow buttons on remote you can scroll down to the
    key line and it appears to let you change some of the numbers
    but there is no method for inputting the additional Hex digits A-F
    Also even though it says "OK" to store it doesnt
    Hopefully a new image will come out that will sort the Update Problem
    or at the very least allows manual entry of keys.
