I have downloaded the latest firmware for my DDigital box but cannot get it on my box. I have got the STB manager to do it but it keeps saying "The downloading is not requested". Do I need to put my box back to factory reset to get it to work? Thanks in antisipation!
Firmware upgrade problem!
The firmware is not a fix though is it? The keys won't work with my current firmware, I'm thinking of updating it.Comment
Hi Gaz, I tried that but it didn't work. If we'r all in the same boat, how did you get yours working? To what extent? I'v got freeview channels but nowt else. How did you flash your firmware? Is there a link to instructions/files. Cheers mateComment
had same problem, tried changing com ports, still with no success, i have a laptop running windows vista , my life sux without this box, so how did you fix yours mate?Comment
To manually enter the ***s do the following:
Press menu,system settings,system info. Then press o.k. A blue box appears -go to nagra & press ok twice. Up pops the key table. Select D+ on the right and edit the ***s then exit press red o.k to save. Then completely exit out.
If done right ya picture will come on.
Keymaster is on this site, just do a searchLast edited by a1.gaz; 30 November, 2008, 14:33.Comment
thanx gaz but tried TW keys so far not working am gon try the other keys, Johnny, you will need to connect the box to your computer. If your comp has a 9 pin male serial com socket ,you need a Serial RS232 9-Pin Female to Female cable, if not then you will need a 9 pin Serial to USB adapter to go with the F to F RS232 serial. I tried it with no success, but give it a go mate, maybe you might be the lucky 1.Last edited by beecrack; 1 December, 2008, 12:10.Comment
