DIGIVOX XL manual key entry
  • Dj dee
    • 60
    #31
    DIGIVOX XL
    Ladies and Gentlemen,
    I pleased to announce that I'm up and running.
    Thanks to all those STRONG charactors who never sleep but work hard for the rest of us. I nearly gave up last night.
    Big up devilfish for keeping the forum running!
    Big up horatio for helping out, I owe u a big tank of booze!
    Big up the entire Digital kaos.
    • GARYF123
      • 7
      #32
      Help needed for newbee!
      Like everybody else, my Digivox XL has gone down. Followed instructions to get keys but just ended up with a screen saying Keymaster & Decrypt. The screen says: CW keys, TW keys, Pure keys etc! What am i not doing?? Please help!
      Many thanks,
      Gary.
      • stinkamuffin
        • 51
        #33
        Hi there Gary
        Have you looked at post 4 on this thread? I am not sure when you say you get to the Keymaster/decrypt screen whether there is info in the keys? If not, you need to download the new keys which are under a thread called Keymaster V1.2. You then type in the corresponding keys dependant on who your service provider is.
        Hope this helps.
        • GARYF123
          • 7
          #34
          Hi Stinkamuffin!
          Yes, went to post 4 and clicked on ###keys are here###. This took me to decrypt screen with titles like cw keys, tw keys etc. But i dont know what to do from here!
          Gary.
          • stinkamuffin
            • 51
            #35
            Sorry ....
            Originally posted by GARYF123
            Hi Stinkamuffin!
            Gary.
            Gary,
            So sorry not to have seen your msg until now.
            Have you sorted it?
            • stinkamuffin
              • 51
              #36
              Sorry ....
              Hi Stinkamuffin!
              Gary.
              Sorry Gary,
              I have not seen your reply until now.
              Do you still need help?
              • GARYF123
                • 7
                #37
                Hi Stinkamuffin!
                Yes, sure do! Unsure what to do, as in need step by step instruction, told you i was a novice!
                Many thanks in advance,
                Gary.
                • jasbo7
                  • 1432
                  #38
                  digivox manual entry
                  Once you have the keys use remote.
                  1) press menu on your remote
                  2) go to system information and press 1004. A hidden menu will pop up which from top to bottom should say, Nagravion, Set default key, Key EMU.
                  3) make sure Key EMU is ON
                  4) next go into Nagravision
                  5) using the remote input the keys and make sure you press OK to store, there will be 2 keys to enter so make sure you do them both.
                  6) exit back to tv and that should be you.
                  Thanks to bugaloo for info
                  • lescoll
                    #39
                    try putting in one line of keys and press ok save then do th 01 key and save again this should do it
                    • MANCUHESTER UNITED
                      • 8
                      #40
                      n..l dublin new code
                      Heres a code that works on digivox xl
                      first reset to factory settings pin 0000
                      Then go to systems info
                      Put in 1004 to entre sub menu
                      Turn on emu
                      Then go to nagravision and change key data .00.to
                      Then store and change to .01. and write
                      **********************. Then store
                      Most of them number are set in already u only need to change 1 or 2
                      After that just retune in channels and ur good
                      Last Chance, post 1 more Key and your having a holiday m8
                      • KISSANEPAT1
                        #41
                        BEST WAY TO UPLOAD FILE
                        HOW DO I UPLOAD THIS FILE TO DIGIVOX ?
                        • grandie222
                          • 4
                          #42
                          hi every one could some one please help me, ( digivox v03.28000bk)
                          boot version01
                          i rest to factory setting and now all channels are gonne,is ther any thing can fix that,thanks to all of you.
                          • grandie222
                            • 4
                            #43
                            boot version01
                            • Fraser Adams
                              Download
                              Sorry guys. I am new to this as well. How do I download a new key
                              • jasbo7
                                • 1432
                                #45
                                Download winrar (google it ) then go to keymaster. Previous threads will tell the rest.
                                Merry Christmas
