vpn
  • tubs
    • 420
    vpn
    what is vpn i am,hereing about and would it help me with kview 780 and if any good how do u set it up
  • masur123
    • Aug 2009
    • 674
    VPN is a Virtual Private Network. If you use a provider like Goldenfrog it will encrypt all your data between you and their servers and then the internet.
    Basically the ISP can not see what you are doing or where you are going.
    • tubs
      • 420
      vpn
      that must be a good thing then how do you set it up
      • masur123
        • Aug 2009
        • 674
        Well you will need either a pay or free vpn provider.
        You will need to set up the connection in your network connections.
        There are plenty of step by step instructions available on the interweb depending on your system.
        • billy2
          • 1381
          have a read here m8 VPN IP Tunneling - VPN UK, USA, Spain, Canada, Germany, France, Netherlands, Switzerland VPN services. and then here VPN IP Tunneling - UK, USA, Spain, Germany and Switzerland VPN tunneling services. you also can get a free 24hrs free trial ( its ends at 12pm every night so ask for trial after that )
          • rhiadad
            • 18
            hi i use edimax router and mobile bb dongle payasgo reg in made up name
