*****WARNING**** VIRUS IN ARNET LOADER SOFTWARE
  • thewizardofodds
    • 924
    The arnet loader software here
    Digital Kaos - Downloads - Arnet Kryptview Loader
    shows as having Win32:Searches-E trojan. If you've used this I'd recommend scanning your drives.
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Scanned using Norton Corporate and nothing found.
    It's been there since April 08 and no-one has mentioned it before, are you sure it's not something else on your PC?
    Which AV are you using?
    • thewizardofodds
      • 924
      as soon as I click on the link it comes up. im using avast
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        OK I've replaced it, please try now.
        • xenafan
          • 64
          Just tried it M8 running Avast as well downloaded ok no probems but shows as a trojan like you say when extracting have had this problem with Avast before M8 but checks out ok with other virus software same problem with other cracks etc bit misleading it usually is ok and trojan free.
          Hope this helps
          cheers
          Xenafan
          • thewizardofodds
            • 924
            same
            also scanned here and shows up on 2 out of 39. theres summit there but looks like it might not be that serious
            • wiccamiss
              • 5
              Hi there, ive tried downloading this loader. Apart from the avast alert. When i try to extract the file with winrar im having problems. Help please as im a wee bit clueless about this kind of thing.
              • mark015
                • 254
                scanned with kaspersky full security suite all is ok no virus found..
                • dctyper
                  • 2539
                  i would recomend everyone gets rid of norton and any other anti virus because they are pants, trust me i know too well.
                  ive tried at least 6 big name anti virus and only one is good enough
                  search for superantispyware in google and let it scan your pc, you will be surprised
                  • IAN LEVER
                    • 15
                    thanks for help ----up & running no trojan found!
                    • Fspiders
                      • 107
                      Avast is well known for having a database of programs that are blacklisted. Most keygens and basically any program that is reported they add to there database.
                      I have two versions of Avast and one is paid for and the other one isn't the one that isn't paid for reports the loader as having a virus. My paid for Avast on my lappy does not see a problem with the same file!!!!
                      Nearly every keygen program that goes through my non paid for Avast comes back as a virus.
                      There's reports on forums that Avast incorporated this into an update to deter people using keygens on their own software.
                      I've made Avast ignore this file as I have with many it's reported. If in doubt run malwarebytes on the file. If that says it's clear then you can bet it is.
                      Regards.
                      • wiccamiss
                        • 5
                        When i try and use winrar on the file this is what i get.
                        ! C:\\Temp\DownTool_0927.rar: Unexpected end of archive
                        ! C:\\Temp\DownTool_0927.rar: CRC failed in DownTool_0927.exe. The file is corrupt
                        What does it mean and what can i do to get this file to work???
                        • kenmonu
                          • 153
                          post's
                          Originally posted by heather
                          tHANKS A BUNCH! JUST JOINED YOU AND YOU WON'T LET ME DOWNLOAD FIXES? WHY???
                          think you need 5 posts before you can download. "capitals" shouting wont help.
