starview lan /krypt lan virgin B/B
  • pomster
    • Mar 2009
    • 119
    #16
    Originally posted by Montebox
    Where did you hear that there are problems with virgin bb? I have a KV a780 with Virgin bb and I've had no problems.
    Just connect your KV to your router via Ethernet and it auto connects - no problems.
    There is a KV a780 tutorial video on Youtube which shows you how easy it is!
    YouTube - Setting up the Kryptview KV780 Cable Receiver
    Cheers for this! do i need a server to do this?
    • cactikid
      • 12017
      #17
      all built into firmware.
      • javaoverride
        • 71
        #18
        FYI when some one says not to use VM bb for IKS/ICS it is because VM use Deep Packet Inspection
        • trevor1969
          • 361
          #19
          could u explainew more please
          • satsmo
            • 6397
            #20
            Here is a small insert for DPI Deep packet inspection - Wikipedia, the free encyclopedia to be honest DPI has much better uses than inquiring into CS packets.
            If you are worried use a VPN which has been discussed time and time again. You have been around for quite a bit and know the pros and cons of these type of STBs in relation to circumventing the latest levels of encryption.
            • pomster
              • Mar 2009
              • 119
              #21
              Is this firmware updated? if it is how easy is it to obtain an is it easy to load on the box?
              • chunder
                • 91
                #22
                Thanks for this guys. Very helpful.
