eurovox help
  • gpz900
    • 8
    eurovox help
    can any one help with my eurovox max v black 2008 ive tried all the links downloads etc no joy i can download software firmware etc no problem. but im not getting anywhere updating channels i need a link for latest firmware, keys ,codes etc that has worked for you,im going to try altering the symble rates see if this helps can you pm me if you can help thanks ITS ALL SORTED NOW UP AND RUNNING AGAIN AFTER ALTERING SYMBAL RATES .
  • muskey11
    instuctions
    after installing firmware, connect box back to tv. press menu. go across to fast install, press ok. change frequency to887. press ok. channels will update. you will see a number at the top 770. when the number in front reaches 770 the number will turn to 35. channels will start appearing on screen. when the number in front reaches 35 one of the channels will come on tv automatically. job done. exit as normal using menu or exit button. cheers, muskey
