Theres some top itgate members on here.....plasterer andiwell..shamus.. freck to mention a few i,m sure between us we get you there!
TGS220 cannot change image (TGS220 != NO SUPPORT) ?? :S
Try Backing up your var/ bin folder
and also var /etc folder from your working box.
Then transfer them to the non working box change attributes to 755 ,and should be good to go .
Theres a var folder posted loaded with CCcam
Hope this helps ........PaulIf your Happy with the Help push the Thanx button
PAUL
hey there thanks for your reply. i tried this but no luck... the cams dont seem to work. when i open the box with dcc the files that i transfered are there and i see them on the tv also but they are not working...
nobody knows how to manually install cam files???
the ccam.cfg file is ok its not that. i am sure of that because i used the same as the other receiver that works fine. i even tried a new ccam.cfg but still. here in cyprus its the same thing as in the rest of the world. u add the modified ccam.cfg file in var/etc and also a newcamd.list in var/keys for working with mgcamd. until i was able to download them on the box through internet everything worked smoothly. i am sure 100% that the way getting out of this is by installing manually mgcamd1.35 and ccam2104 files on the receiver.... but i just cant find the way...Comment
i mean by inerting them through ftp and then manually installing them from the box. i did this once with a dm500s as i added an mg_cfg file to var/keys and then added 3 tar files to /tmp and manually installed them from the receiver. it worked fine then. with my tgs220 that dont seem to work... and its the same image that i am using....Comment
