780 prob, box comes on then 4 lines on display
  • bigshack
    • Nov 2010
    • 7
    well as title says i took the 780 of from the network(disconnected from tv modem and and cable supply) it was workin fine then when i reconnected it the box came on it says on ,on the 780 lcd then for a couple of seconds it says power search mode on the tv screen then the display on the box goes to 4 small lines and stays like that havent tried to reflash it yet untill i get the ok from one of the more educated ppl on D K hope some can point me in the right direction
    thanks Big
  • barrowmanandrew
    • 3427
    check your cable feed is in correctly nice and tight...
    you have put it in the correct place and not the loop out?
    the 4 horizontal lines means that no signal is being received.
    • cactikid
      • 12017
      sounds like signal issue,check if there is a problem in your area also,and you may have to reboot all units again,box.modem.router,as said make sure coaxial in correct port.
      does no signal come up on screen now? indicating there is a breakdown or not connected coaxial.
      • wullieace
        • 49
        press power button on remote m8
        • DW190
          Simple bur from what the op has written it appears he needs to switch the box on.
          Power Scan came on screen means he switched it off and because the cable has been disconnected it needs to be on again for the time to reset on the clock hence the four dashes.
          • bigshack
            • Nov 2010
            • 7
            like to say a big thanks to the good ppl at D K(above) for the help they gave as simple as tighten cable and hittin the power button on the remote as good as new happy days,cheers
            • DW190
              Thanks for letting us know.
