24\03\2011 Firmware. Go to installation section of the menu and select S\W update.
New 24\03\2011 Kryptview Firmware
Quote from KV
"Just a minor addition. In the menu there is system information. If you press the green button then it checks the ip. Two reasons for this just a quick check to see if the box is connected to the net and most importantly if you are using a vpn then you can make sure that is working. It brings up the ipinformation given is to be used for educational purposes only
Don't Forget To Say Thanks If You Like My Post
IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
If It Ain't Broke Don't Fix ItComment
quick question i have updated the firmware, and all the channels are fine i haven't done a factory reset after the update nor scanned the channels they were already there and working, and all the +1 channels that wern't working are now working, so do i still need to do a factory reset?
or should i stick to the "if its not broken don't fixit it" method
Hillsborough 15th of April 198996
id stick with if its working leave it alone.quick question i have updated the firmware, and all the channels are fine i haven't done a factory reset after the update nor scanned the channels they were already there and working, and all the +1 channels that wern't working are now working, so do i still need to do a factory reset?
?Comment
channels missing
i have updated my kv A780 done a scan and have lost itv1 and channel 4. anyonr have any idea how to get them back pleaseComment
