help needed newbie woman
  • mandyzcutz
    • Apr 2011
    • 13
    Please help. I cant get my kryptview A780 working i dont know what im doing?
  • Evastar
    • Apr 2009
    • 1220
    the kv server isn't working at the moment mandy, but should be back soon.
    meanwhile, read the sticky threads at the top of this forum, they will tell you what you need to do.
    any questions after you have read them, come back and someone will help you out
    • ianso
      • 31
      This must be the most helpful forum on the net guys well done everyone for making it the best
      • Evastar
        • Apr 2009
        • 1220
        this might help you mandy:
        [ame="http://www.youtube.com/watch?v=Q2RbdhH7_b4"]YouTube - Flashing the KV780[/ame]
        [ame="http://www.youtube.com/watch?v=LsEvfBnceiM"]YouTube - Setting up the Kryptview KV780 Cable Receiver[/ame]
        • mandyzcutz
          • Apr 2011
          • 13
          Tried all that and says code file size error please help
          • Evastar
            • Apr 2009
            • 1220
            at what point exactly does it say that, and what is the name of the file and the file extension please eg .txt .rar etc?
            do you have the correct bin file dated 03.01.2011?
            and the loader dated 30th november 2008?
            • cactikid
              • 12017
              server is starting again,sports 1 2 3 and nickleodeon reported working
              if your box was working before it went off maybe just needs a reboot of box modem and router [ off for 30 secs then on ]
              • mandyzcutz
                • Apr 2011
                • 13
                loader is dated 30/11/08
                bin file is 05/09/10
                lets me click download then chose file in code send then when i press start comes up with code file size error
                • mandyzcutz
                  • Apr 2011
                  • 13
                  No hun its a new box needs setting up .
                  • Evastar
                    • Apr 2009
                    • 1220
                    i can't see that bin file, try the one here: Digital Kaos - Downloads - Arnet Kryptview
                    • DW190
                      Did you extract the file after downloading?
                      Where abouts are you? If your close to me I'll come and sort you out and get ya box working.
                      • cactikid
                        • 12017
                        what pc do you have hopefully its a xp and you have a serial port/rs232 port and you got a null modem cable?
                        all new boxes come with fta firmware and will need flashing,it says its the kryptview 780 yes.
                        • mandyzcutz
                          • Apr 2011
                          • 13
                          HI Eva tried that its now saying the downloading id not requested but i have got no channels hardly. Maimly got chanel 5s
                          • BJTT
                            • May 2010
                            • 223
                            MandyZcutz, Go To This Website:-
                            4shared - My 4shared - shared folder - free file sharing and storage#
                            Open KV780 Folder? In Said Folder Download & Save DownTool 0927.Exe To Your My Documents.
                            Then Open Old Folder In Said KV 780 Folder?
                            In Old Folder You Notice @ Bottom of Said Firmware List? Firmware File KV_ A780_24/08/2010 Download & Save Said Firmware Into My Documents? Trust Me, The Said Firmware Is Old But Sound. When You Done Said Manouvers? Connect Cable That Evastar Has Shown You Via You Tube To Your PC I Believe Its An R232 Cable.
                            Anyway, Connect Said Cable To Your PC. Switch Off Your KV Box Via Red Power Off Button On KV Remote & Switch Off Black Switch On The Back of The Said Box? Switch Should Be Pressed Up The Way, To Power Down Said Box? Disconect From You TV & Cable, & Ethernet Cable From Box To Router Or Modem, & Disconect Scart Plug From Back Of Said Box, & Remove Electrical Plug.
                            Plug Box Into Mains Near Your PC, Conect R232 White Cable Into Said Box From PC. Power Up Said Box Via Rear Switch. Open Power Down Tool In Your My Documents On Your PC Maximise Windown Centre Square Top Right Hand Corner Click On Download Tab, In Said Window.
                            In Said Box That Pops Up Named "Code Send" Click On File Tab & Look For Your My Documents Folder. In My Documents Folder Click On KV_A780_24082010_Bin & Said Firmware Will Now Be In Your Code Send File Coloumn. Take KV Remote & Press Top Left Hand Corner Red On/Off Button Then Click On Start Button On Code Send Box Then Point KV Remote To KV Box & Press Red Button Twice Next To Green Button & Top Red Button On/Off Once. You Will Notice In Said Code Send Box Firmware Will Start To Load From 0% Up To 100% Once It Has Completed That Task You Will Notice It Will Start To Flashburn Said Box Once It's Completed That Task It Should Come Up "Download Sucessful" Wait Till It States "Download Sucessful" Before Turning Off & Disconeting Said Box From PC. By The Way, Before You Disconect Your KV Box From Your TV Press The Menu Button On Your KV Remote Select Top Task It Should Be On Said Tab Stating The Word "Instulation" When Password Box Appears Type "0000" In Said Cascading Menu Which Appears After You Have Typed "0000" In Said Menu You Will See "Factory Default" Select Said Choice & Hit Okay This Will Reset Your Box Back To Factory Settings.
                            Do This Before You Disconect Your Box & Conect It To Your PC To Be Flashed. Let Me Know How You Get On By Following Said Instructions?
                            • DW190
                              The flashing method here is outdated. Leave the box power off until you have hit the start button then power on.
                              Forget all the pressing of the coloured buttons. Powering on after pressing start does the trick.
