24-03-2011firmware
This topic is closed.
  • swifty
    • 63
    24-03-2011firmware
    hi guys where can i get the firmware 24-03-2011
  • tubs
    • 420
    if i am right firmwere does not work or does not exist as up date does not work youshould be able to download shight from box thats what i have been told
    • lac
      • Apr 2011
      • 213
      This is what the March update was for.
      Quote from KV
      "Just a minor addition. In the menu there is system information. If you press the green button then it checks the ip. Two reasons for this just a quick check to see if the box is connected to the net and most importantly if you are using a vpn then you can make sure that is working. It brings up the ip"
      • bees2000
        • 61
        There is no bin file available for the march software it was loaded via sw update option on the box when everything was working.
        03/01/2011 is the latest file available its in the download section you will need a null modem cable to flash
