Hi guys what's the best way to run two tv's off a vm box, I have run sat cable to the other sat outlet, what do I need to get it working!!
How to run two tv's off a vm box
If it's the one box you want to view on Two Tv's then i think the easiest way is with an AV sender.
if you already have coax running and presuming its a kv your using on vm network then i would use a rf modulator and also a remote extender if you want to be able to change channels in bedroom also. A wired connection is always superior if when possible.Comment
