Kryptview A780 Change Net Id
  • bickyz
    • Jul 2011
    • 11
    is it possible to change the net id in A780. I want to select different town from the net id list. Also before it used to show all the town name but now it shows all town as "Already Exist".
    thank you, help will be much appreciated.
  • cactikid
    • 12017
    factory reset/default ok 0000 to delete and when done power off at back for a min clears all info and sets box back to blank so you rescan from scratch.
    • Rien1988
      • Jun 2011
      • 51
      Already exists usually happens when the Ethernet cable is still plugged in remove the ethernet cable during the scan process
      • bickyz
        • Jul 2011
        • 11
        i unplugged the ethernet cable before doing a scan but still it shows Already Exists 51 times.
        • cactikid
          • 12017
          follow post 2 like i said.
          • bickyz
            • Jul 2011
            • 11
            will factory reset erase the patch that has been done to the box i.e. do i need to re-patch the box to get the other channels.
            • astro77
              • 470
              No just do as cactikid said
              • cactikid
                • 12017
                [ame=http://www.youtube.com/watch?v=LsEvfBnceiM&feature=related]***x202a;Setting up the Kryptview KV780 Cable Receiver***x202c;‏ - YouTube[/ame]
                factory reset only erases channel data
                reflashing over rides previous firmware.
                • phil b
                  why do people ask for info then do there own thing !!!
