If I cancel VM Subscription
  • unplayable
    • Apr 2011
    • 40
    If I end my VM contract (phone/TV/broadband) will i lose my signal and be UNABLE to watch KV??
  • homer41
    • 207
    u can cancel ur tv and split ur line from your BB. but if you cancel your tv and BB then yes u should in the ideal world lose the signal for your kv. your phone does not matter
    • MICKAH
      • 96
      once you start splitting your BB, dont expect the signal to be high or of good quality, pay a min sub, that way your TV signal will remain good quality, the signal will be reduced if you remain with BBAND, but you will need BBAND for the Krypt to work, so you will have to bear this in mind before doing anything
      • zee24
        • 3342
        how cme b4 nagra3 came in the old boxes use to work without the cable connection being active? what i mean is my uncle moved in to a new house he dnt have cable tv or anything or bband, i got him a eurovox box all we did is plug the old cable connection from previous owners n it worked
        • cgscott
          • 3513
          The feed would have still been live. They rarely turn off the connections. It means going to the exchange box and doing it from there.
          Long time ago i used to go down and reconnect them for that use alone.
          Patience is a virtue.
          • Montebox
            • Aug 2008
            • 216
            My KV runs perfectly with just phone and broadband. I've never had Virgin TV. Even my old redundant dbox2 ran OK too.
            Just get the basic BB and phone package and use a splitter to your KV box. I've been doing this for years now
            • Rien1988
              • Jun 2011
              • 51
              You don't get any more of a signal level with or without the tv package it's a standard line there's not different strengths, its the same line that comes in ur modem and tv, before I've had my starview box and it was fine now I have the kyrptview and my signal level is 88, and i only have broadband, make sure there's not any unused splitters going anywhere in the house if so remove them this can decrease the signal level
              • ozzy12
                • Apr 2011
                • 66
                it may work out cheaper to get basic virgin tv, phone and broadbrand package rather than just the broadband and phone subsription.
                • careless1979
                  • Apr 2011
                  • 53
                  88 sig is fine.
                  Why Does Stuff Cost So Much ? And GET OFF MY LAWN.
                  • sigmadelta58
                    • May 2010
                    • 93
                    I was d/c from NTL cable 3 yrs ago, no prob with KV, I get everything just the same.
                    There will always be the odd glitch, but hey! its a freebie.
