Display Issue
  • snook123
    • 59
    Display Issue
    Hi I have a power issue I think. intermittently the picture to the TV goes off for a split-second then back on then off. it can do this for a while then be ok again but its happening more often. is there anywhere I can send this to be fixed? had it 18 months or so. Anyone else seen this problem its a 750 with I connector. maybe I should buy another as its paid for its self 10 times over!!
  • Dazza2008
    • Jun 2011
    • 29
    its called glitching buddy...
    mines going abit crazy.. it was like it yesterday and when i switched it on at 7am this morning BBC1,2 ITV1 channel 4 has gone AWOL LOL just hang fire it should sort itself out in time i know it can be abit of a head case but its free so live with it LOL..... saying that BBC1 and ITV1 better be working tonight for emmerdale and eastenders LMFAO
    • snook123
      • 59
      no its not glitching. the actual signal to the tv goes off and on through the scart lead. its like the box turns off then back on but very quickly.
      • ziezou
        • Sep 2009
        • 125
        Try new scart lead or it may be the tv you could also try using the coloured wires as well before purchasing a new box.
        • cactikid
          • 12017
          also make sure power plugs are getting a good connection if they are those crappy 2 pins ones.
          • lincsat
            • 1228
            You could also try the other scart socket on the box, but you would have to manually select the AV channel on the TV.
            • alex123
              • 832
              these channels are fta not a kv problem but a vm problem are you in teeside they seem to be working on the lines there
              • snook123
                • 59
                Hi great reply s I will do all of the above and let you know cheers
