Kryptview a750
DW190 -
DW190
If you have two lights, with your box and iconnector switched on, first reboot your router and wait for five minutes, then with the channel on S/sports1 switch your box off at the back wait 10 seconds and power back on, wait another five minutes. If your still on two lights pull the power plug from the iconnector and after ten seconds plug it back in.
Give it at least twenty minutes without doing anything else.
It is advisable to disconnect any other devices from you router while doing the above.
Still no joy check the null modem cable on another device.Comment
DW190
One light is power only.
Try reflashing the firmware to the iconnector. Its done the same was as flashing a box and a link has been put in a previous post.
You aint anywhere near Bolton r u?Comment
hi mate im in notts... i have reflashed the iconn... i now have 2 lights, but still no good, i cant imagine life without this box
DW190
Do you know anyone who has a A750 that you can try you iconnector on.
From whats happening, or for better words, not happening you need to do some elimination.
I'm a bit of a distance away or would have tested it for you.Comment
cheers DW sometimes when i plug the iconn in it says module updating but just hangs on that screen for ages and does nothing else? the bloody i connector is a fiddly thing does my head in
DW190
Module updating should count up to 100% on your box.
But from your other post I see its sorted.Comment
its gone again! i think its the iconnector thats causing a problem! has anyone got a spare one i can buy off them?Comment
managed to get the box on today by changing the power supply to the iconnector, i thought all my problems were over, then all of a sudden after 5 minutes the lnk light started blinking and off went the box, so i reset the iconnect it came on again for about 5 minutes then the lnk light started again, any ideas guys? is my iconnector on its last legs?Comment
