After the software update i can only get 8 TP's were i used to have 50 odd as a result i only get 6 channels i'm all ears
,did you factory reset then power off at rear for 30 secs to remove old tp data? then power on and autoscan from direct feed no splitters,also remove lan before scan,net ids may have changed for you also.insert lan after channels have loaded and if needed reboot box modem and router to gain a connection.
