urgent help
  • deepthought
    • Nov 2011
    urgent help
    kryptview a780 is tempermental keeps scrambled and video,have tried s/w updates but the problem still occurs anybody got a solution to solve this annoying problem....would be grateful for a rapid response if possible..thanks
  • guppyabby
    • 232
    same here m8 no solution yet.
    • mentorman
      • Oct 2008
      • 166
      Tempremental !
      Hi there , we all suffer with the "Scrambled channel and No Video" from time to time when the server is busy or the guys are working on it ! Your problem might be a local problem with VM or you have splitters in your setup which reduces signal strength etc. If your mains VM cable from the wall to the box has a home made F.Connector on the end that you made up yourself.....check the end for a good connection and that none of the outside strands are making contact with the central copper contact !! Try and delete all channels and do a Factory reset after uploading the new update online etc. Make sure you have the best NET iD for your area when you do a scan for channels and leave out the Ethernet cable from the back of the box whilst you do the scan ok . Hopefully these suggestions may put you back on track . Good Luck !
      • ziezou
        • Sep 2009
        • 125
        Its the box mate been a nightmare for the last 24 hours, only solution is buy a better box.
        • deepthought
          • Nov 2011
          thank you for your help ,when you said new update on line which site would you recommend for me to use .as i said before many thanks for your help
          • ASEK
            • Feb 2010
            • 1686
            it's on he box menu 0000 down to s/w update magic if it's there
