a780 probs
  • ronnyp
    • 27
    a780 probs
    is any-one else having same prob as me, bought a Kryptview a780 of a friend but when I connect up done a facory default then rescan all channels are there but when I try to watch any they keep going off. They freeze then I get the message Scrambled opr no video. I have tried everything. tried different net IDs even changed cables. it is unwatchable so am thinking of disconecting it
  • cactikid
    • 12017
    sounds as your signal is low,what is the signal and quality readings,can you put your box on the main cable feed with no splitters and recheck again.
    • ronnyp
      • 27
      not using any splitters, plugged straight into router, not sure how to check signal strength
      • cactikid
        • 12017
        on any channel at bottom it should have lines for signal quality and signal level.they should be at around 77 / 88%
        • ronnyp
          • 27
          s = 88 q = 72
          • cactikid
            • 12017
            that should be just good enough,what date is on firmware on box?
            menu........system info...?
            it should read 29112011
            • ronnyp
              • 27
              its 29/11/2011
              • cactikid
                • 12017
                try powering off at rear for a min,box,modem and router and then on,sometimes this clears any problems.
                • ronnyp
                  • 27
                  just tried this and don't know if it has cleared or not but been working for about 10 mins now which is about 9 mins longer than it has been. I'm off to bed now. Thanks for your help, will try it again tomorrow and let you know results. cheers
                  • ronnyp
                    • 27
                    still glitching and freezing every 30 secs or so.fTA chanels are ok its just the encrypted ones it does this on. Getting fed up now and think I'll disconect it
                    • taffydav
                      • Apr 2011
                      • 333
                      try rebootin yer router m8
                      • ronnyp
                        • 27
                        tried rebooting modem, router and box just the same
                        • durasoft
                          • Aug 2008
                          • 57
                          worth a try
                          Hi, try taking router out of line and plug internet into back of A780 if you have a seperate modem/router. If that solves your problem then your router is stopping the A780 talking to the cardserver now and then. I put an old router in line and it sorted my problem like you had. It could be a port issue, try putting your A780 in the DMZ in router set up. Find what mac/address your A780 is on and then put that in the DMZ. I hardly get any freezing anymore.
                          Just thgt it worth a try.......Regards T
                          Humax FoxSat-HDR
                          Great HD/SD Box with 500GB HardDrive
                          Manhatton HH-120 42E-30W
                          Triax 88cm 0.3db
                          SKYBOX F3
                          HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
                          Intel Core i7 [email protected]
                          MSI R7970 Twin Frozr Boost Edition
                          • ronnyp
                            • 27
                            Hi, I don't have a clue as to what you mean, what is DMZ
                            • ronnyp
                              • 27
                              any more ideas befor I bin it
