bham,not picking up all channels? splitter/coaxial feed problem?
  • wakkaday
    • 148
    i am not picking up all the channels on my kv box, it has the latest firmware. april 2012.
    i have tried using the direct feed straight to the box, but its still only picking up the same number of channels as to when i also use a splitter/internet modem connection setup?
    im trying to figure out what the problem is likely to be?
    when i have had the channels in the past they have been glitching and i get a no video/scramble message. this has been more of an occurance since having my new vm superhub installed..is there any settings i can change in the router perhaps?
  • calverley
    • 74
    there is 2 birmingham scans have you tried both more channels on 36 hope this helps were in brum are you.
    • wakkaday
      • 148
      central...i picked telewest...
      • calverley
        • 74
        yes thats right but you can have the pick of to scans number 34 on the list birmingham or 36 birmingham on the list to scan use 36 to get max channel 34 will limit amount of channels you get.
        • wakkaday
          • 148
          how do i get 34 or 36 to choose from? which setting is that in. i just to automatic scan and select birmingham 750 and let it scan...generally finds 56 responders.
          • cactikid
            • 12017
            what is your signal and quality readings,if low you will not get all channels.
            • ASEK
              • Feb 2010
              • 1686
              u have latest s/w on box?
              • wakkaday
                • 148
                yeh i have latest april firmware 2012
                signal
                quality
                when i go to automatic search , telewest, tp search
                signal strengh quality is 56
                reading for signal quality is 0
                but when i do an automatic scan picking up the net id, birminngham 750, the signal bar goes to 80 and back down again and fluctuates between 80 and lower...
                • calverley
                  • 74
                  menu installation /code 0000/ factory default ok / then scan telewest on birmingham 36 listing area iam in brum to
