kryptview not powering on
  • faflefevre
    • 163
    #16
    its looking like you have a faulty power supply board....
    leave it with me till the morning as there is 2 parts that lose value and cause this fault i will check what the boards reference numbers are...
    i could possible repair or supply a working board..
    im not sure of the sites rules on this is it looks like im advertising for work
    • shahchad87
      • Aug 2012
      • 11
      #17
      Another thing I realised while testing the voltage was that the voltage would slightly start to drop the longer I held on to the pin. Would that suggest a faulty capacitor on the PSU bosrd ?
      • faflefevre
        • 163
        #18
        the parts to check on the power board are d8 (diode)..
        c13 (2200 10v) c15 (100 16) have a look at these 2 caps to see if they are doomed or bulging...put your finger on the top to check if doomed or not.....
        your 12v line is a bit high.....
        if these parts seem ok you may be best changing the whole power board..
        im about 85% sure your faults on the power board but could be wrong...
        i have a kv with a working power board and a fault on the main board..so i suppose if you removed the main board sent it to me i could tell you 100% if its faulty or not
        • cactikid
          • 12017
          #19
          out of interest do you use surge protection on all your units?
          • shahchad87
            • Aug 2012
            • 11
            #20
            The C13 capacitor top was clearly bulging from the rest of the caps. So ordered a replacement from eBay and replaced it today. Worked a treat, thanks faflefevre!
            • cactikid
              • 12017
              #21
              are you using surge protection??
              • shahchad87
                • Aug 2012
                • 11
                #22
                It is plugged straight into the wall socket.
                • cactikid
                  • 12017
                  #23
                  no protection from power surges then.
                  • faflefevre
                    • 163
                    #24
                    well done m8 gald its sorted..
                    its nothing to do with electricity surges.
                    its due to age and heat its common on all electronics especially televisions..
                    if you had a surge it would blow the internal fuse or damage the primary of the power supply.
                    your fault was on the secondry of the power supply..
                    the older starview 1 boxes used to give the same problem on the 3.3v line and would freese up and display a 0 in the display..
                    anyway glad i was of some help.
                    and good advise from cactikid about surge protectors may prevent killing your eqipment for goog
                    • cactikid
                      • 12017
                      #25
                      after sv1 i used surge protection on cable and sat,power and internet so no back door entrance.
                      are you using a good quality scart with no loose connections as i have been told that may damage caps also.
                      • faflefevre
                        • 163
                        #26
                        you have been told wrong m8...
                        the only way a scart cable can damage a cap is if you used a scart cable as a weapon and physically hit the cap with the cable
