ONLY HD CHANNELS SHOWING AFTER FACTORY RESET
  • THECABLEMAN
    • Mar 2009
    • 13
    Hi Fellow viewers.
    Am concerned. Last two days completely lost signal for all channels.
    Today carried out fact rest, and rescanned, router off, power on box off and rebooted router and box. I have done this several times and the only channels being picked up and stored on the box are HD channels...any suggestions whats going on ?
    SEregion
    are you using a splitter by any chance
    • cactikid
      • 12017
      always scan from direct feed with coaxial cable and lan removed,correct netids used?insert lan and reboot if needed.
      • THECABLEMAN
        • Mar 2009
        • 13
        Hi, no splitter being used. Also the free-2-air channels are listed and working. Just every single known non-HD channel is missing. I have also searched under different areas and have tried manual tuning...but still no joy. :-(
        • THECABLEMAN
          • Mar 2009
          • 13
          I understand...I did infact only scan by coaxial. I wonder whether something has gone down in the area perhaps.
          • alex123
            • 832
            there is something wrong with your scanning settings or you tuner is faulty 0r net id can you try box to box transfer from another box and what box you have 780 or 790
            and change your user name to hopetobthecableman
            • THECABLEMAN
              • Mar 2009
              • 13
              A780, never had problems before. I have now also noticed that Signal Strenght is Good, however the Signal Quality is virtually gone and sometimes bounces more or less full bar.
              I have then tested NETID for way up north...guess what it is picking up some prem channels...very bizarre behaviour!
              Also, does anyone know what the purpose is for the 'Data Dload' option under menu? when would you use this option?
                Posted in wrong section sorry what bellend i am.................
                • lac
                  • Apr 2011
                  • 213
                  Data D/l is box to box Software/channels
                  If you have a VM box correct NetID can be obtained from it,Setting - Tech Stuff - Network ID ?????
                  If no VM box say what area your at and someone maybe able to say what your NetID is
                  Factory reset scan from wall socket without splitter
                  Menu - System Info ---What date does it show.?
                  1819 is for Starview boxes
                  • cactikid
                    • 12017
                    remember net ids are changing,anything to throw a spanner in the works,
                    • THECABLEMAN
                      • Mar 2009
                      • 13
                      Everyone, thanks for all the advice's. I managed to resolve the problem, had to manually tune in all the different channels using NetID from a further location. It's doing the trick. Thanks Again. peace.
                      • faflefevre
                        • 163
                        change your name to hopetobthecableman only you could come up with that one alex
