A780 Not Working Or Updating
  • BJTT
    • May 2010
    • 223
    I live in the Glasgow Area anyway the Firmware that I have on my STB is 24/4/11 nearly everytime that I go into the
    instalation menu and select software update it nearly always
    sticks on 'Searching For Update' infact I have to select 'Exit'
    to come out of said mode becuase it's stuck in this mode
    and will not budge. I have had my STB now for some while
    I normaly go to 'Reset To Factory Defualt' re-scan which
    normally sorts out the said problem & when I go back to
    'Searching For Update' it comes back with a message stating
    that my STB is 'Already Updated' Last night there I had the
    same problem as the thread posted on the 21/9/12 by cactikid where said search was only coming back with
    looking for 'Eight Channels' instead of the normal 'Forty Six'
    my Area comes under N*L reading between the lines my
    STB's main problem is that is does not update regularly
    infact over the past three years that I have had the STB
    the 'Update' function is only worked about two to three times which is not right. I have quite a few past 'Firmwares' in my
    collection for my STB & I'm open to suggestions? as mentioned my main problem is that my STB is not updating
    regularly which is a nuisance as mentioned the latest firmware that I'm using is 24/4/11 hopefully I will be able
    to get the 26/4/11 firmware although this is also another
    problem due to the fact that said firmware is not available
    via DK downloads & Is also not available on another useful
    website that I use for firmware updates entilted
    'My4Shared Website' check it out folks and you will see
    what I mean as regards to a useful STB firmware update
    & Download Tools website 'My4Shared' so to recap my STB
    problem is basically down to 1) The Firmware 24/4/11 not
    being updated to 26/4/11 & 2) The Searching For Update
    Command not functioning properly or regularly any useful
    tips or advice folks? Speak with you all again soon.
    Until then, I hope you all have a peachy cool day.
    Sincerely, BJTT.
  • ASEK
    • Feb 2010
    • 1686
    have you tryed it with no splitters just direct feed from street and internet connected?
    • lac
      • Apr 2011
      • 213
      Update manually using 29/11/11 then try using remote for latest firmware.
      • BJTT
        • May 2010
        • 223
        Yes ASEK, I have tried it with no spliters and I'm still getting the same problem. Thanks for your help ASEK.
        Hi Lac, thanks for the info, I have just tried what you have suggested re:-firmware 29/11/2011 via
        My4Shared website and guess what? still no joy
        just now I'm looking @ the s/w update screen
        which is stuck on 'searching new update' I'll go
        and check the downloads page on DK and see if
        there is any firmware that I have missed out on
        I'll let you both know how I get on in due course
        thanks for your advice much appreciated
        speak with you both later. all the best, and
        God Bless, sincerely, BJTT.
        • lac
          • Apr 2011
          • 213
          Can't check perhaps the online update is down.
          • BJTT
            • May 2010
            • 223
            lac, I think maybe also the problem here is that because
            I have done so many reset to factory default untold amount of times maybe the box has reached it's limit
            what I'm going to do is reset the software back to the
            original software and take it onwards from there.
            I also noticed when I checked system details it's saying
            the version is 3.00 which is strange considering that
            the original software that comes with the stb when it's new states the version is 3.02 I'll let you know how I
            • BJTT
              • May 2010
              • 223
              that's really weird, I reset the stb to the official/original
              software and low and behold it picks up 47 frequency's
              55 frequency paths 505 channels & 38 Radio Stations but
              low and behold because of said software it only picks up
              fta channels my stb seams to have a mind of it's own.
              • BJTT
                • May 2010
                • 223
                phoned vermin found out through altimated message that error messages appearing on screen throughout the UK
                informed that engineers are looking into said problem
                another stb that I have has just confirmed said problem
                with signal strength only @ 56% which is naff also signal
                quality is non exsistant which is not good news either
                hence recent problems oh well it looks like I'll just have
                to settle with sky tv tonight which I have as back up
                hopefully vermin will have said problem resolved in the
                next day or two patience is the key here anyway folks
                I hope you all have a pleasant weekend until we speak
                again cheers from BJTT
                • alex123
                  • 832
                  i did an update today via lan and worked ok lot of guys with problems in glasgow last few days even worse for the ones with 790 can you not do box to box from a friends box ?
                  • ASEK
                    • Feb 2010
                    • 1686
                    alex is Glasgow turning off analogue tv signals soon?
                    • cactikid
                      • 12017
                      Digital switchover dates in the United Kingdom - Wikipedia, the free encyclopedia
                      did you try rebooting box modem and router as in off for 30 secs then on,remove coaxial and after a min try a s/w update.
                      • faflefevre
                        • 163
                        when trying to update via lan..are you getting the lights on the ethernet port..if not your ethernet port is faulty thats why it wont update via server..
                        • cactikid
                          • 12017
                          if lan port was faulty would that not make box a fta only?
                          • cmero
                            • Aug 2008
                            • 15
                            hi mate had major issues same as you crashing locking up etc, i reflashed it via pc to late flash avalible from dec 2011 and rescanned for update and loaded, channels scan as need to renew list and mine been fine since
