krptview crashes , showing zero
  • cybalokz
    • Mar 2009
    • 7
    Hi guys
    I have a kryptview a780, it shutdowns after approx 40 mins displaying a 0 on the dispaly. will only start back up after being off for several hours.
    I believe it may by a faulty power supply board / dodgy caps. any tips on how test which cap/ board it could be there is no visible bulging on the caps that i can see. or whicjhs caps if any it could be.
  • lac
    • Apr 2011
    • 213
    Disconnect box from power supply open up and check for leaking or bulging caps.
    Overheating may be the problem,vent the box.
    • cybalokz
      • Mar 2009
      • 7
      ive had a good loook No bulging caps no visible leaking, i have ran the box vented.
      • astro77
        • 470
        run your finger over the caps a visual check won't always show up a bad cap
        • cybalokz
          • Mar 2009
          • 7
          tried running my finger across the top nothing noticable.
          • cimlaboy
            • Oct 2012
            kryptview crashes
            Hi guys, just ordered a new Kryptview A780 and was wondering how often the channels crash. I've yet to recieve and set my box but I am wondering now if I have wasted my money. Cheers in advance.....newbie
            • faflefevre
              • 163
              check your 3.3v line with multimeter..have a look at my older posts theres 2 caps in the secondry of the power supply that fail also a diode can go faulty had this fault a few times now
              • waterpistol
                • Oct 2012
                • 9
                Originally posted by cybalokz
                Hi guys
                wow; i've just had this problem too except it happened to me perhaps 20 minutes into a viewing. have you had this problem continuously since your post? have you had to remove the cap and put another in its place?
                • cybalokz
                  • Mar 2009
                  • 7
                  still having same problem. tried changing two caps still same issuse.
                  which is the 3.3v line?
                  • faflefevre
                    • 163
                    its the line coming out of the power supply that reads 3.3v
