Glitching!! Driving me mad
  • snizzle
    • 10
    Is there anything I can do to stop the Glitching? I'm using a vm hub! When I scan and choose the area closest to me I don't get all the channels, I'm in Wigan and have to use knowsley! It's just doing my head in! Iv updated to the latest firmware! Is there anything I can do!! Any help would be appreciated!!
  • cactikid
    • 12017
    what is your latest firmware?any kak splitters and are you 100% sure you have correct net id=dont think so.
    • ASEK
      • Feb 2010
      • 1686
      is wigan not manchester?
      • snizzle
        • 10
        I have 11/11/2012 pv4.1.05 Iv scanned with no splitter! Iv chosen manchester 1 2 3 and Manchester trails but I don't get all the channels!
        • astro77
          • 470
          you factory reseting between each scan mate
          • cactikid
            • 12017
            to be 100% get net id off vm box,you have checked for vm faults in area?
            • lac
              • Apr 2011
              • 213
              Try,40967 [Preston 1] Telewest,scanning on Network NOT on all
              • mentorman
                • Oct 2008
                • 166
                GLITCHING !
                hi there, i have had similar problems like this in the past and so i deleted all the channels from my box first then did a factory reset 3 times after uploading the latest update... then eventually i got a better scan receiving more transponders etc etc resulting in all channels again !
                • snizzle
                  • 10
                  Yes mate!!!
                  • snizzle
                    • 10
                    Which box?
                    • snizzle
                      • 10
                      What box? One in the street?
                      • snizzle
                        • 10
                        I will have a go thanks pal!
                        • cactikid
                          • 12017
                          vm sub box in house,or check with the neighbours one.
                          • dab2000
                            • Oct 2010
                            • 6
                            glitching can be caused by a few things
                            1- high server loads at pm times especially when kids are not at school and when people are not at work
                            2- dodgy connection. i had this with a brand new cable replaced it and it fixed the problem.
                            3- interference from another device.. i had this every time i turned my pc on but this was fixed when i replaced cable
                            these are a few just a few things i have had problems with.
                            do you have glitching early in the morning and with any of the free channels if so its certain its a connection problem. you can have good signal and still have problems with a dodgy cable or splitter.
                            high server loads can be a problem.but i havnt had none of these problems in the last few weeks.
                            i see your not getting all the channels so i would say its a connection problem
                            hope this helps
                            • astro77
                              • 470
                              hope this helps
                              Wow second post in two years
