glitching still as bad as ever i seen on one post krypview are aware of the problem does anyone no if there doing anything about it.
glitching
OK guys need some help - hope someone can assist.
I have two KV boxes running, the a850 HD in the front room (which is working fine and running of the main feed)
And I have the A750 + iconnector. The A750 feed is split between the superhub and the box. This seems to be the reason the channels are distorting/glitching (as i've tried swapping the boxes over with the same result).
Is there any sort of signal booster that could sort the glitching out, the FTA channels seem to be fine its just the pay channels which are causing issues.
Pls help
thanks!Comment
there is nothing wrong with my set up ihave 2 boxes i connect the krypview it has the pv.4.1.05 software 11/11/2012 its connected to the superhub the signal is 88 the quality is 79 it glitches and freezes every 4/5 mins if i take the krypview of and connect the starview in exactly the same way ie same cable same ethernet lead same superhub there are no problems at all.i have tried all the suggestions on this website nothing has worked.dont no if you can help any further but will try all sugestions. thanks.Comment
this has been posted before so worth a try as he has the 780 and the hub.
Ok since I last posted I decided to switch my not so super hub into
modem mode(WiFi off) and connected to the hub a netgear dual band
wireless N router brought off eBay for 35quid.
Then connected my kV 780 to the new router. After using this method for
over a week I have seen a vast improvement I rarely get a scrambled
message with loss of picture. And channels that were previously terrible
are watchable again as at worst the picture will freeze every 5mins or
so for 2secs with the sound continuing then picture resumes.
I know this may not work for every but if ur still struggling with bad
reliability buying a decent 300m wireless N router for 20quid and using
this method I highly recommend.
At worst if this method doesn't improve ur viewing you'll have better
WiFi range as in my case and many others the super hubs wireless signal
was poor. .Comment
Thanks for that cactikid.
I have tried that and also tried connecting the superhub straight to the KV A750. Still no joy. Let me just give you a biref discription.
In 1 room I have the KV A850 HD running fine with no probs (the feed is coming from outside the house using a splitter)
In the 2nd room I have feed (which is also connected to the same splitter outside) and the feed is split again in the 2nd room - 1 line going to the superhub and the 2nd line going to the KV A750. The A750 glitches/freezes on 98% of the paid channels, however FTA is fine.
I have tried the suggestion of switching superhub to modem mode and connecting another wireless hub. Still have no joy.
The a750 with i connector is on s/w date 28/02/2013
The signal levels are between 82-88. The Quality levels occassional drop to 0. sometime 58 and sometimes 72.
I hope someone can help. It would be very much appreciated
PS. I've rebooted network the main channels which are not working are sky movies and sky sports 1...Any suggestionsLast edited by kingdomk; 9 March, 2013, 15:44.Comment
thanks mate but i have tried this didnt work if the superhubs the problem perhaps we need some super software.this has been posted before so worth a try as he has the 780 and the hub.
was poor. .Comment
