which box?
This topic is closed.
  • jubz
    • May 2010
    • 116
    which box?
    Hi everyone, So I have heard the kryptview a780 is no good as it glitches alot, so can anyone recommend me boxes that require no cardsh*ring cable or sattellite boxes. Like the blade bm7000s, that is similar to the kryptview but needs a server. Do all sattelite boxes need card*haring or is their boxes that have it without. Thanks
  • manxspud
    • 1768
    Erm no and no ... only one i can think of is the one that comes with your s*y subscription.
    Hope that clears it up for you
    • jubz
      • May 2010
      • 116
      Im sure there are other boxes, the box that has 2 in 1 forgot what the name was
      • manxspud
        • 1768
        Are you asking about boxes that do both sat and cable !!!
        Cause the way i'm reading it ... you are asking if there are boxes that allow you to view cable/sat without the need for a server !!!
        • jubz
          • May 2010
          • 116
          Yes, I heard they are the best, macca told me
          • finshady
            • Jan 2012
            kv a780 is the best box
            • manxspud
              • 1768
              Which bit are you saying yes to ...
              yes to sat and cable
              or yes to not needing a server !!!
              just so i can put you on the right path
              • BJTT
                • May 2010
                • 223
                So Blade BM 7000S Is the way to go then? How much money does said STB cost?
                • jubz
                  • May 2010
                  • 116
                  A box without a server, sorry
                  • jubz
                    • May 2010
                    • 116
                    Does the blade bm7000s need a server? Or does it work like the a780
                    • manxspud
                      • 1768
                      Ah macca m8 your a case
                      Sorry but are you really telling me that after nearly 3yrs on here you don't know the basics ... really !!!
                      • BJTT
                        • May 2010
                        • 223
                        & So are you ManxSpud being a case. I've heard in the past that Blade STB are linked with C***sh*r*ng
                          not my fault although such talk is not allowed on dk
                          • BJTT
                            • May 2010
                            • 223
                            Okay modulator we will keep it under mums the word
                            • manxspud
                              • 1768
                              I give up
                              laters lads
                              Should have realized that a cable lad would not know how his own box works
