kryptview dead ? pls help
  • stanley baxster
    • 36
    Hi Guys,
    I've reflashed the box ..factory reset..rescanned with network cable out/in ..but i get no channels ..
    the netid list does not appear just goes straight to scan ..reflashed again ..unplugged for 30 mins ..nothing works ! ..done this routine about 4 times
    btw cable is definatley plugged in both ends ...!
    PLEASE HELP ..or should I chuck in the bin ?
  • Hadron
    • Nov 2012
    • 2102
    Which model of Kryptview have you got?
    Which version of firmware did you flash it with?
    • stanley baxster
      • 36
      Kryptview_A780_ 111112 ..the latest one if found was this
      • ASEK
        • Feb 2010
        • 1686
        you had trouble last week with sky sports gone, did u ever get correct netid? because u never replied
        • stanley baxster
          • 36
          Hi Asek, yeah sorry thought I'd had replied, never sorted that either, been trying to get it back but lost everything in the meantime ..can't seem to get Netid list to appear and now box stuck in a scan loop i.e no channels at all.. tried all the obvious ..reflash ..factory reset ..rescan all variations i can think of.
          • ASEK
            • Feb 2010
            • 1686
            what s/w version is on box?
            • stanley baxster
              • 36
              system info says :
              software v pV4 105
              H/W v3.0.0
              • ASEK
                • Feb 2010
                • 1686
                date 11/11/2012 ?
                • stanley baxster
                  • 36
                  yep thats right
                  • ASEK
                    • Feb 2010
                    • 1686
                    do u have correct area netid from a subbed box or do u know for certain what it is?
                    • stanley baxster
                      • 36
                      when i bought the box I was told to use Manchester3 ...which i have done ..I've found that Manchester 1 and 2 also worked ..but have mostly stuck to 3
                      • ASEK
                        • Feb 2010
                        • 1686
                        well u have to be sure of this or u will be missing channels if its wrong, u got ur kv handy?
                        • stanley baxster
                          • 36
                          well Manchester 3 was the recommended and in the past thats been working fine with all channels present, the KV is close by yes
                          • ASEK
                            • Feb 2010
                            • 1686
                            well go to menu installation password factory default and hit ok for now then comeback
                            • stanley baxster
                              • 36
                              yes done that ..looking at install screen ...next ?
