GLITCHING
  • tatty1
    • 21
    GLITCHING
    my kv780 been glitching all day in birmingham area any one else having problems thanks
  • cactikid
    • 12017
    yes many,seems vm meddling again
    • tezbob
      • 37
      Mines down altogether Manchester area......
      • Mic260
        • 209
        But it has nothing to do with VM-They can't "meddle" with KV-It's a KV problem
        • cactikid
          • 12017
          course they can meddle,updating areas lan problems channel movement have an affect on the kv,if kv went down everbodies box would also be down but they were not is my point.
          • Mic260
            • 209
            But that's not meddling with the KV per se. It's simply VM constantly trying to update its service and makes changes. This cannot be compared to how VM used to GENUINELY meddle with Starview boxes for example before N3 encryption by changing the codes
            • cactikid
              • 12017
              ah the good old days ,4 changes in 1 day brilliant hehehe,did not work forums in meltdown.
              yes vm constantly updating / meddling / changing things no idea how long more it will take.
              • gji25
                • Feb 2010
                • 353
                i dont know if you realise this or not but the kryptview glitching problem has been going on for 2 years now
                dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
                • sigmadelta58
                  • May 2010
                  • 93
                  I agree, but the glitching has got progressively worse during the last few weeks, as it did just before n3.
                  Branson is no fool, so I also suspect vm are doing there thing.
                  • cactikid
                    • 12017
                    before n3 you just had a coaxial feed,now you have a lan feed also,with a lower signal bad cabling and bad routers and better say bad box there will be issues,how many people try and fix them or just complain?
                    what setup are you using as the more info we are told the more chance something may be done?
