scrambled or no video
  • danale
    • Oct 2011
    • 9
    "scrambled or no video " appearing every few minutes. have updatd, re-scanned and no outside issues. anyone help?
  • cactikid
    • 12017
    sounds like a lan issue,have you rebooted box and router?
    • TheCoder
      • Jun 2011
      • 693
      In situation where your actually receiving the channel rescanning is fairly pointless as the channel is obviously available on the frequency the box already has. A rescan generally only has use where you actually lose a channel (because its been relocated to a different frequency) and even then the autoscan function (which works when the box is in standby, if enabled) should sort the problem.
      4 times out of 5, that message would imply a codeword delivery problem. Somewhere between the box and the cardshare server information is either not being produced, being lost or being significantly slowed.
      • nevglufc
        • Feb 2013
        • 6
        Hi I am also getting this display in the manchester area. I can get BBC1 no problems but all sports and movies get the scambled display. any help appreciated
        • cactikid
          • 12017
          new firmware in downloads,null modem flash cable time and follow the tuts
          • Denzel1219
            • Apr 2010
            • 20
            hi up date my box its stuck at 100percent and stays there and then nothing any on help me pls
            • MrSweet1991
              • May 2013
              This is a common issue, although this is a nice feature it is proving unreliable. However the old way works much better. You need to manually upload the firmware using a computer. This is accomplished by inserting a null modem cable into the computer and then into the kryptview, once done there is software that will essentially push the bin file (firmware) to the kryptview box so it flashes it that way. The null modem method seems fairly straight forward and there are plenty of tutorials (even youtube) to show you how to do this.
              • nevglufc
                • Feb 2013
                • 6
                Yep that worked for me, got a cable of web ?2 and used an old laptop I had with windows me on it, loaded a treat. I updated with the Nov file by mistake and then did a sw update on box and picked up the latest download. Cheers
                • cactikid
                  • 12017
                  always best to state what it was
                  new date 26052013 for the 780
                  • gedastra
                    • 29
                    HELLO I HAVE THE SAME PROBLEM AS YOU , HAVE YOU HAD ANY LUCK FIXING IT ?? AND ALSO ON ONE OF YOUR REPLIES IT SAYS HAVE YOU REBOOTED BOX AND ROUTER ?? IVE REBOOTED THE BOX BUT WOULD REBOOTING MY MODEM HELP ME ?? AND IF SO HOW DO YOU REBOOT A MODEM ?? JUST SWITCH IT OF AND ON ???THANKS
                    • cactikid
                      • 12017
                      ohhh my poor ears again ,getting a headache now .
                      powering off all units at rear for 30 secs then on is rebooting=to regain an ip address and to clear any bugs stored.
