hi people can any 1 tell me where I can get firmware for the phoenix hd box can not see it it the download section???
phoenix hd box
Tags: None
well on the ad it says comes with fta firmware. but not yet got the box . was trying to get it from some where incaese it dos only come with fta fermare. is it not on the dl section here . if not can you advise me where I can find it.Comment
no ya wont
first time flashing this box changes it from a terrestrial box to a cable box.
firmware is not posted on any forum but ask your supplier where to get it
and no it does not come with the box.
flashing the box
Please follow the instructions below
(1) Format a usb pen drive to FAT32 on your PC first
(2) Then get the file you have downloaded and copy it across to the usb then
(3) Turn the box off at the back and put the USB into the front of the box
(4) Then turn the power back on to the box when the box powers up go to the menu and select Software upgrade press ok
(5) Then allow the box to reboot, after that you will see the cable scan option just scan as with the older box
Ps if you see on screen usb initializing all the time your USB pen has not been formatted to Fat 32
GUYS WHEN SCANNING FOR CHANNELS YOU MIGHT NEED TO SCAN ON ALL OF THE PROVIDERS MAKING SURE YOU FACTORY DEFAULT THE BOX EACH TIME, SO IF NO CHANNELS ON SCAN ON N*l SCAN ON EXCW, THEN TW, AREAS HAVE CHANGED OVER THE LAST FEW WEEKS AND AREAS HAVE BEEN CHANGEDComment
you should know by now box can only be purchased with fta on it.
