think u need to suss this out, u need a cable feed from vermin that carries tv signal u also need a broadband feed from whoever the hell u want to pay for it, but u need 2 cables into ur box
You will probably be OK for a while, as they won't physically disconnect you straight away. I left VM nearly 3 years ago, but I'm still connected in the green cabinet.
However, should anyone need to work on the cabinet for any reason, there's a chance that I will be disconnected.
To use a Kryptview box you need a VM cable connection to the green cabinet by subscribing to one of their services, even if it's only broadband.
If you cancel your broadband service, as I did nearly 3 years ago, they do not immediately disconnect you from the cabinet, but there is no guarantee that you will be connected for ever. You could be disconnected at any time.
If you want to guarantee your cable connection you need to keep subscibing to one or more VM services.
