im thinking of getting the a850 modded hd box will it work allright and will i beable to flash it with mk1 vermin super hub
a850
you dont need your superhub to flash box,only firmware and usb stick.
flashing the box
Please follow the instructions below
(1) Format a usb pen drive to FAT32 on your PC first
(2) Then get the file you have downloaded and copy it across to the usb then
(3) Turn the box off at the back and put the USB into the front of the box
(4) Then turn the power back on to the box when the box powers up go to the menu and select Software upgrade press ok
(5) Then allow the box to reboot, after that you will see the cable scan option just scan as with the older box
Ps if you see on screen usb initializing all the time your USB pen has not been formatted to Fat 32
GUYS WHEN SCANNING FOR CHANNELS YOU MIGHT NEED TO SCAN ON ALL OF THE PROVIDERS MAKING SURE YOU FACTORY DEFAULT THE BOX EACH TIME, SO IF NO CHANNELS ON SCAN ON N*l SCAN ON EXCW, THEN TW, AREAS HAVE CHANGED OVER THE LAST FEW WEEKS AND AREAS HAVE BEEN CHANGED
use a hdmi cable instead of scart and not both to tv. -
