kv
  • derek08
    • Feb 2010
    • 51
    kv
    flashed my box with the latest firmware after completed the download my kv box has went to on in the front panel and the box is not responding to the control any help please on what to do thanks
  • ASEK
    • Feb 2010
    • 1686
    reflash must not have been a good one
    • derek08
      • Feb 2010
      • 51
      cheers for that what is the best one to use thanks
      • Digicom
        • 190
        Kryptview_A780_26052013 : May 25th 2013 then use sw update in box
        • derek08
          • Feb 2010
          • 51
          thanks for that i will do it and let you know if it works
          • derek08
            • Feb 2010
            • 51
            Hi there tried again the box is not responding it has just got on in the front panel no response wat so ever nothing with the remote control wont power off or on no response from the buttons on the box as well. stuck ?
            • Digicom
              • 190
              Turn off your Kv by on/off switch on back then press Start on Loader
              then turn the Kryptview back on you shud then see the fw starting to load,
              • ASEK
                • Feb 2010
                • 1686
                when u flashed it did u see it saying downloading and download complete on loader page?
                • cactikid
                  • 12017
                  what box as you have not said yet.
                  • derek08
                    • Feb 2010
                    • 51
                    hi there sorry its the kva780 still just stuck on at the front panel no response from control or buttons on box never said loading when i was up dating with firmware yhanks
                    • cactikid
                      • 12017
                      recheck what firmware file you used on box,sounds like a bad flash,did box reboot when done?
                      • Digicom
                        • 190
                        Turn box off using the switch on back
                        then press Start on Loader and turn box back on
                        you should then see the fw starting to load,
                        Follow the Firmware Loading Guide
