Attenuator for the 850
This topic is closed.
  • roblfcx5
    • Nov 2012
    • 239
    Hi guys jus little advice pls, is it worth wile buying a attenuator for the 850. ? If so wich one, I see they come in diff watts does this make a difference ,if so wich is best 1 to use if they work
    Not got 850 set up yet I no with reading threads
    That they are do freeze unless modified but before I go down that route I thought I'd try attenuator, if they work
    Any help be much appreciated.
  • roblfcx5
    • Nov 2012
    • 239
    I think I've been looking at the wrong one
    Is the correct 1 0-20db signal attenuator with f connections the correct 1 ? ?4.25 eBay ?
    • lenordy
      • Mar 2009
      • 244
      don't no about the 850 mate but I tried 3 different size attenuators on the a780 made no difference at all .
      • roblfcx5
        • Nov 2012
        • 239
        Cheers won't bother buying an attenator then
        If I'm going down the modified route for a 850
        Is this worth wile sending off ? Or is that not wrth the hassle either ?
        • ASEK
          • Feb 2010
          • 1686
          have u already bought the 850?
          • roblfcx5
            • Nov 2012
            • 239
            No m8 not yet
            • cactikid
              • 12017
              new boxes should have it already done,verify with dealer its done already.
              • roblfcx5
                • Nov 2012
                • 239
                Oh gutted I already bought now for 2 ton and its not moddified its glitching like mad, weres best place to get this sorted m8.
                • faflefevre
                  • 163
                  are you 100% sure it hasnt been modded..i can pm you with a link and if you could send a clear photo of your power board i can confirm if it has or hasnt been done
                  • roblfcx5
                    • Nov 2012
                    • 239
                    Ok bud I'm of down south today f concert
                    So will do this when i get back early next wk thanks,
                    I dout it is as tho as its a lot lot worst thn 780
                    Cheers m8
                    • cactikid
                      • 12017
                      scanned on wrong provider/netid etc rebooted box and router?
                      • alex123
                        • 832
                        you got a bargain then guy on ebay I recommend will fix it names fix my socket in middlesbrough
                        • roblfcx5
                          • Nov 2012
                          • 239
                          Looked on eBay the last week can't find anyone on there who does the modification ?
                          Is there anywhere else that I can post out to ?
                          • ChrisLawn
                            The guy from Middlesbrough is on here and he has probably already PMd you. I wiill just say he does a great job and I no longer need an attenuator on my 850.
                            • faflefevre
                              • 163
                              thats right i have sent him a pm twice he has my website address
