Kryptview Firmware Loading Guide / Tutorial.
hi to everyone on d k.i am immi,i hope to make a lot of friends and be of help to the digital kaos members offering my free service from time to time on most make of motor cars mechanical wise,please do not mind the spellings.only offering to the members because of the site and that is digitalkaos.so if u got a probleme with ur car ,if near could also fix 4 free u buy ur carparts 1member at a time please as its getting could.Comment
Great Tutorial.....guys, just downloaded and flashed the firmware as per instructions. went into auto install and got nowhere with it...says it found 7 channels but will not go past installation screen. by the way i'm on nthell in waterford ireland. any help would be appreciated-thanks
A lot of problems people face with channel search is due to the fact that the flashing and subsequent isntallation (easy install) has to be done without the receiver being switched off.
If after the flashing, the box is for some reason switched off (as in my case, i was flashing in a seperate room on my laptop and then carried the box to the room where my TV was), the installation to get channels would not work. The box can be switched off once the scan etc is complete.Comment
yes same question here
im new so im a little confused about this whole process
KRYPTVIEW A780 - FILE LOADING
Hi everyone
I'm wondering if someone can come to my rescue.
I have gone through the steps as illustrated on this thread, but could not load the file.
I get a message "The downloading is not requested".
I am using 2 cables (null famale to male cable & USB converter) with a small famale connector in between the cables. Nothing is happening.
Could someone put some green light.
I have checked the COM port.
Would it be the cables?? I could not find a single cable.
Your help will be much appreciated.Last edited by Dj dee; 21 November, 2010, 13:37.Comment
Turn off box. Hit start on loader. Turn on boxHi everyone
Your help will be much appreciated.Comment
i tried downloading the firmware it is coming down as a bin file and will not let me open it can someone help pleaseComment
